Help!!!!
I had a local oddd job man fit a new bathroom suite for me yesterday. and today I have had to:
1) put a new push fit flexi pipe to hot water on the bath as the crimp on the one that he had used was leaking
2) replace waste on bath room shink as that was also leaking
3) replace doughnut on close couple toilet as that was leaking ( although that still appears to have a very slight leak, have tighten wing nuts one more turn (I was advised not to tighten too much as prone to cracking pan)
and now I have just found that the the toilet waste is leaking, I have used some plumbers glue ( he left a pot behind) on it and it is still leaking, it is slightly off set and goes into 3.5 cast iron. trouble is I couldn't get an offset reduced coupling so I had to get a 3.5 - 4" straight and then an off set pan connector. When he fitted it yesterday he cut the 3.5 straight slightly short and said that it wouldn't matter as at least half the fins were inside the C.I. how do I stop this from leaking do I have to go and buy a new one?
I already have to redo some of the 90° on the feed as they are leaking through the back nuts.
would've been easier and £100 chepaer to fit it myself.
close to tears pen pusher
