I've just redone some plumbing in my house, basically changed the pipes between the radiator in the kitchen and the central heating pipes, we did not touch the boiler whatsoever. Now there is a leak coming from inside the boiler. once the pipes were replaced we filled the central heating pipes with water, the pipes that were changed work fine unfortunately for some reason there is now a very small leak coming from the central heating return pipe. I have no idea why this is happening and was hoping someone would be able to give me some ideas.
1) Boiler make / model (gas or oil) = Gas Baxi Combi 80e
2) What is / is not happening = Leak from the hot water return pipe (I think its from there anyway)
3) Has ANYTHING else been done / changed recently = Just the old pipes nothing to the boiler
4) When did it (problem) start = Once the water was turned back on
5) When does it happen? eg, heating coming on or going off = All the time
6) Anything else you feel may be of relevance = Just the new pipes but I don't think they woul make a difference
8 ) DO NOT post a question under this message, this is for information only
9 ) try to remember we are only seeing what you type not the job !!
