Had to change cistern fill valve which i thought would have been like for like replacement (easy) haha.
bought a fluidmaster and realised when went to fit, that new ones threaded shank is 10mm shorter than old one, this poses a problem because of the fittings i am connecting to. (see picture).
I have used couple of washers to prop up fitting, also used 1mm thick polythene washer in the cistern side to get the shank at correct height to connect to fitting.
But the problem is once tryed it, had a leak at the polythene washer inside the cistern.
has any one any advice on a fix for this (e.g better way of sealing using thin washer like polythene one) or a completely different suggestion or advice ???
hope above makes sense cheers
