I have a Worcester 18/25 external oil fired combi which was only fitted 2 months ago. The pressure drops after just a few hours so suspecting a leak I called back the fitter. He says there must be a pipe leaking somewhere under the floor but as he didn't fit the pipes he's going to charge a small fortune to find the leak as it involves removing and refitting lots of floorboards, carpets and tiled floors etc etc. This week i've exposed all the pipework and can't find any leaks whatsoever. I was told it could be a faulty expansion vessel and to but a poly bag over it, repressurize and leave overnight but the next morning nothing in the bag and no pressure again. Today I have tried closing both the flow and return valves in the boiler and then repressurizing the boiler. After just a couple of hours the pressure is dropping. There has never been any water under or inside the boiler so I am guessing the boiler is leaking internally. We have noticed that we get a lot of steam vapor from the flue but just though it was due to the very cold weather.
My question is, could the boiler be leaking internally into the combustion chamber and the water coming out as steam through the flue or could there be another reason. I just don't want to call out Worcester when there could be some other simple explanation.
Any help would be appreciated
