Hi all,
I've tried fixing my leaking dishwasher, a two year old Kenwood KDW4TTSL, which is leaking from the door. I think I have done what's within my skillset and now it's between getting in a professional in to look at it or to get a new one. Or maybe somebody here has an idea what else I could try.
Any advice is appreciated!
Description:
When I switch it on, first it pumps out any remaining water. Then fresh water is being pumped in and the machine starts filling up quite a bit -maybe an inch from the bottom. After about 2.5min the water starts leaking out of the bottom right of the door and also some holes on the underside of the dishwasher.
I checked the top seals and they seem reasonable clean and intact, but so does the seal along the door.
I've taken off the spray arm and it doesn't seem to be clogged and the waste water pump is also working.
Any recommendations?
Description:
