My son has a lean-to conservatory across the back of his mid-terraced house. In February 2007 the whole roof had to be replaced due to storm damage (insurance paid ). Later that year the house walls were cavity insulated, although at the back they were only able to do the part above the conservatory.
Last winter water started to appear on the back wall of the house. It seemed to be coming from the main cross member tying the roof to the house. The installer came (10 year warranty) and diagnosed it as a failure of the seal. Which was repaired using a sealant gun.
The same problem has arisen again in this very wet weather (the conservatory faces due south). The installers came along last week and this time said the problem is due to failure of the pointing. They said they had filled some of the worst holes with sealant, but the back wall really needed re-pointing.
I would have thought that any water permeating the bricks would creep down through the cavity insulation (which stops about where the roof joins the back wall) and then drop down the cavity to the damp-proof course. There is no sign of any water at that level or of any water leaching out of the wall. It all seems to come from the main cross member tying the roof to the house.
Does any of this make sense? Is it a pointing problem or a conservatory roof problem?
