Hi
We purchased a conservatory from B & * last summer, which is made by and supplied through Cestr*m conservatories, B & * say they are just the agents (don't know if I can mention names here?)
Anyhow the panels all came pre-glazed and slid into the sill which in turn is screwed to the brick work, the conservatory is full hight glazed and the panels are held together via alloy slide in bars and are covered by plastic strips which just clip over the alloy bars. Water is getting into the sill and pouring onto the floor. We siliconed all the parts as instructed in the installation manual and video, however because a lot of the parts just clip in place, water is finding many routes down the pre-glazed panels, including between the glass and rubber seals, all this water is filling the sill up and soaking through the brick work and through every clip together panel that are too tight a joint to silicon but not tight enough to stop water. We think the whole thing needs taking apart and re-doing. We've tried contacting the supplier direct, they say it's not their conservatory even though their phone number is on the assembly instructions, B & * are sat on the fence and are in the process of saying their trying to sort things out with their supplier. In the mean time we're stuck with an unwanted indoor swimming pool. We just wandered has anyone had any similar experiences and what was the conclusion, any advice will be welcomed though.
Thanks Alan
Thanks Alan
