Hi - i have a bosch dishwasher, not been used for ~ 1 yr. just tried to get it going again.
leaking from the base (only when not level or if moved ) and getting stuck right at the end of a cycle "1 minute remaining" (it then leaks after reseting and stopping the cycle manually. if i tip it up it seems to leak from the adjustable leg holes (2nd front set that are set back from the front of the unit)
Any thoughts?
model is SGS55E12GB
Have seen on the web comments of "seal drying out and shrinking after prolonged storage", "antiflood device activated if leaking at the base" - can't see any obvious way to open it up to look....
cheers
Rich
Any thoughts?
model is SGS55E12GB
cheers
Rich
