I'm hoping someone might be able to help.
The double check valve under my kitchen sink is leaking. I originally thought it was the bottom join which connects to the pipe that was leaking but it is the middle (which doesn't have a screw marking on it) - which I believe is the valve itself...
Not sure if I have described that correctly but I'm wondering if I will just need to get it replaced or is there anything I can do to fix it myself?
Any help would be very much appreciated!
Thanks very much...
Thanks very much...
