This drain valve is leaking and looks a pig to replace, the pipe starts to curve immediately after that fitting.
Trying to nip it up is pretty unsuccesful and indeed seems to be making things worse. Is there any change that I can pull the guts of the existing valve out and replace a washer or the like or does the whole valve need to be replaced?
