Leaking flat roof - advice required
  • Thread starter weegieavlover
  • Start date
W
weegieavlover
Hi All,
I had a felt roof applied to my brick built shed roof (actually they are not really sheds they are the old coal and ash stores).
The sheds have 3 walls that are all higher than the shed roof itself. So the felt rises up these walls by about 10-12 inches. I have noticed that a bit of felt has come loose from the wall and is allowing water to penetrate into on of my sheds. It is a not a big piece that is loose but enough to let water in.
What is the best, but cheap if possible, solution to sort this out. I am a DIYer so happy to have a go at most things, however if it involves a blow torch then I would not like to tackle that.
What do you recommend?
Colin
