Leaking floor
26 Feb 2008
I have moved into a house with a separate, walk-in shower room, about 1.2 metres square. It has a tiled floor. The shower room in on the ground floor, which has wooden floorboards. My problem is that the flooring is leaking, so that the hallway carpet gets very wet.
Can I put some sort of covering or sealant on top of the tiles, or will I need to fit new shower room flooring? If I do need a new floor, is there a simple, straightforward way to do it? Or could I tile over the existing tiles?
Thanks for any help.
Skye16
I don't think so, because the waste pipe is on the far side to the hallway. The shower room floor itself doesn't seem too firm, so I think that's where the problem is.
Thanks for your help.
Then it seems that is going to be the cause if you've ruled out the pipework.
You would need to take up the tiles and see what lies beneath,might be just a case of screwing down what is there but more than lightly will need to be replaced.
At the very least you would need to use wbp ply then tank and tape it,best option would be aqua panel or backer boards though.
Thanks for the advice.
Are there any web sites that explain how to fit a new shower room tiled floor? I'm going to have a go at doing it myself in about a week's time, when our visitors have left.
check out the sticky at the top of the tiling section, should be all in there for you, any other questions post a new one.
