Hello,
I bought my first house last summer, it's got an oil fired Grandee boiler controlled by a Grasslin QE2 controller.
When I first moved in the boiler wouldn't fire for heating but it would for hot water so I swapped out the controller and all was good again up to today when I noticed a soggy carpet.
Upon inspection the Sika flow switch is leaking with a slow drip, my first question is can you replace the seal or should I fit a new flow switch?
My second question relates to how this boiler operates, all literature for the controller seems to say that if you want heating / hot water you either need to program it to come on at a set time or press a button to provide an hours worth of heating / hot water, just turning the hot water tap on would not cause the boiler to fire.
This initially seemed strange to me but I put it down to being my first experience of an oil boiler and / or a cr*p control system.
Now this leads me back to the flow switch, what would be it's purpose in this system?... Or was it damaged and not working from the point that I moved in and really the boiler should fire when I turn the hot water tap on???
Thanks,
Andy
Thanks,
Andy
