leaking fridge
8 Oct 2004
The condensation in the fridge builds up too much that it settles at the bottom and so we're always having to clean up. Can anyone suggest anything?
Thanks in advance.
there is normaly a channel below the cooling element whith a hose
leading to a container on the compressor to evaporate the water
follow the channel look for a hole or tube which may need you to
rod it with[i use a peice of 4core telephone wire]flexible wire or maybe
a long cable tie somthing that will fit in the tube without dammaging
the tube and clearing it
in case its not clear you do this from inside the fridge
you dont normaly touch the outside
realy glad it worked sanjjohal
thanks for the feedback we realy appreciate it :D ;)
