Hello hope you can help, have a Gloworm 24CI combi boiler. Kept losing pressure and overflow pipe was dripping, was advised at plumber merchant to change the pressure releif valve, which i did. It is still losing pressure but not leaking out of overflow. On closer inspection it is now dripping from another valve underneath. Looked it up in the manual and it is call the reduced pressure zone valve. It has a threaded nipple thing which is simply leaking. My question is - is it simply a case of changing this valve, manual says you can change the o rings, or is there something else wrong, which is causing this valve to leak as a safety measure - hope this makes sense to someone.
