leaking hinged shower screen
28 May 2009
Sussex
we installed a hinged shower screen, which has a rubber strip against the wall, and a rubber strip along the bath. In the kit, was an L shaped piece of rubber to insert at the corner joint between the two strips, which needed to be pushed in and sealed with silicon sealant. Unfortunately, as the screen gets moved back and forth, the corner joint does not do it's job properly, and is leaking water not only along the end of the bath, but water is travelling along the bottom sealant strip and coming out of the other end! Disaster! Any suggestions on how I can remedy this?
Thanks in advance!
Thanks for your reply. It seems the corner joint is just not very well designed. I'd be happy to replace the strip, but can't really find one that copes with vertical and horizontal rubber seals. Whenever the corner joint hits the wall when it is swung back into position, the silicon splits and back to square one!
I had a similar problem and ended up putting silicone sealant all along the inside and in the corner and making the screen fixed !
It just kept leaking otherwise.
Thanks for your reply - I think it's our only option. Either that or a dreaded shower curtain...!
