Can you believe it, the day after I drain down the system and replace the inhibitor and noise additives the boiler starts leaking! We didn't even go near the boiler during the draining, flushing and refilling. I guess some gunge was happily sealing the potential leak till it got washed away.
Anyway, it's an old Ideal WLX CF60, and it's leaking from the joint face between the two cast iron core halves. It's actually coming out from the top left hand corner, near the bolt that clamps the two halves together. As it's a gravity system, and the leak is near the top of the core, it only leaks a few minutes after the boiler has fired up.
If we use a leak sealer additive I am not sure if we can tolerate the regular dripping until the stuff does its magic work (up to 24 hours the label says) or whether the leak is too much for the sealer's intended purpose.
I have read that the joint seal can be replaced. My question is what kind of seal is it? is it just some special sealant on the mating faces? or something pretty standard sold by the foot? or a manufacturer's part? (which I haven't been able to trace on the WWW). I know it isn't going to be easy, and I could be opening a can of worms with such an old boiler, but it is an otherwise clean condition. Is this the kind of thing that BG deal with in their fixed price deal?
Thanks for reading!
Thanks for reading!
