Hope some one can help, I had a leaky isolator valve on the hot tap below the bath so i drained the hot water and replaced the valve and now i only get a very small amount of hot water from any tap before the water stops and i have to wait ages for more water.
Ive got a condensing boiler down stairs and a hot water tank up stairs, im guessing the hot water tank needs refilling but i thought the smartfit valve would switch over and fill for me?
The header tanks in loft are full and water is clean (full system only fitted 2005) and the radiators etc still work ok, there is a bleed next to the hot water tank (near valve) and that has no air and a bleed above boiler, also no air.
Any thing i should do??
