I have been having a small issue with some leaking joints since yesterday.
I have a Triton Mimosa Dual Control Mixer Shower.
http://secure.tritonshowers.co.uk/media/custom/upload/File-1361538916.pdf
My leaking joints are located on the inlets of the valve main body. These are 1/2" BSP threads and fitted to them are 90degree bends (compression fittings) 1/2" to 15mm.
http://www.plumbcenter.co.uk/en/plu...stex-45-male-iron-elbow-90-degree-15mm-x-1-2/
The leak is on the valve body to fitting. I have to back the fitting out a little in order to pick up on the inlet pipework that runs down the wall, so the fittings are not all the way in. I have used PTFE tape and Plumbers Mait, but the leak persists (albeit small and slow drips).
Additionally, I have a leak from the shower arm to rear entry fitting. The rear entry fitting is basically a male 1/2" BSP thread that picks up on an elbow in the wall, whilst the other end is plain, with two O-rings built into it. The shower arm slides over the fitting and held in place by a grub screw.
http://www.tritonshowers.co.uk/media/15236/shower_arms_rear_entry.pdf
Any help would be greatly appreciated. At the moment I have the whole thing isolated until I fix the leak.
Cheers in advance,
T
Cheers in advance,
T
