LEAKING MIRA 88 SHOWER
2 Apr 2011
Essex
I HAVE REPLACED THE INTERNAL CARTRIDGE ON MY MIRA 88 SHOWER AND IT STILL LEAKS FROM THE SHOWER HEAD. ANY IDEAS WHAT THE PROBLEM MIGHT BE?
The mira 88 don't have a cartridge.
to cure a dripping shower head you need a service kit containing all the seals.
about £15
Thanks, but I replaced the complete inner set but it still leaks. One thing that did happen when I tightened the large hexagonal nut I couldn't turn the shower on. I had to loosen the nut slightly. Could this have anything to do with it?
did you clean out all the scale when you had it apart? and polish up the brass?
and reassemble using silicone grease?
