Leaking Mixer Tap
7 Aug 2006
Lincolnshire
I have a slightly leaking mixer tap. Unscrewing and retightening the taps hasn't solved it. Didn't find any washers to replace. Didn't manage to unscrew central "mixer" tube. Any ideas/thoughts/suggestions? thanks
Hi
Where's it leaking from?
Some mixer tubes are held in by a screw.
Generally more info not enough to give diagnosis.
Hope this helps.
thank for your message. Leaking from main mixer tap shaft ie where the water is supposed to come out. will check tonight to give you further info.
