Leaking monobloc mixer
30 Apr 2008
Nottinghamshire
I think our Franke monobloc single lever kitchen mixer tap needs new o-rings to stop leaking round the swivelling spout. How do I remove the chromed collar above the spout without damaging it? Do I assume it is simply a thread which has seized up with. say, lime? If all else fails I may need to find my oil filter removing tool . . .
Regards,
GordonP
There should be a small screw at the back. You will need a small alan key to loosen it, than you can wiggle it out, and change the o ring.
Thanks for your response. Cannot find any screw. Original installation hints that it may be a simple threaded collar but with a left hand thread. Will investigate and report back.
GordonP.
