- Joined
- 19 Mar 2023
- Messages
- 5
- Reaction score
- 2
- Country
Hi all, wonder if anyone can assist with the below ongoing issue. A few weeks ago, our Vaillant boiler developed an F23 fault. A few weeks prior to that, the overflow pipe from the hot water header tank (gravity fed system) began leaking throughout the day on a daily basis. So, a plumber replaced the ball valve assembly on both the hot and cold water header tanks, in addition to replacing the pump on the heating system. The heating and hot water seems to work fine – however, the outside overflow from the hot water tank continues to leak (always seems to be when the hot water and heating are off), and I noticed the cold water tank leaking from the overflow yesterday (when the heating was on). Every day there is also quite a large amount of air in 2 x downstairs radiators; all other radiators in the house, including the upstairs, have no issues with air in them. Any thoughts on what is causing the daily leaking of the hot water overflow tank please, in addition to the daily air in the radiators? Thanks in advance.
