hi all
Spent a bit of time installing a new toilet with new flex hose and new pan connector.
All went well until I noticed that water was slowly leaking from under the pan.
I looked all around the new pan connector which was dry as a bone, same for the flex hose. I removed and reinstalled ensuring cistern was correctly tightened.
Minutes later it was leaking again, I can’t remember if it leaked after a flush or not.
I then took the toilet apart and checked the pan. lookomg at the pan from inside I could see a hairline crack which appeared to have some sort of white putty on !? This is a brand new toilet.
Anyway I have not tried to put it back together yet as I think this is the culprit.
Has anyone experienced anything similar with a new pan? I can’t believe a crack would just be sealed up !?
Racking my brains about this and I will be until it’s sorted. Hopefully it will be fine with a replacement
