Firstly I a had a shower mixer tap installed on my bath, however due to low water pressure I had to install a stuart Turner pump under the bath to boost the water supply. It seems now with the pump installed that the connection between the tap and the pipe is leaking. Getting to the connection is very difficult as there is no room to tighten the connect anymore than it is. Is there anyway of fixing this leak without removing the bath i.e a special tool or a mould I can fix onto the connection. I really want to avoid removing the bath as that will be a big job
