Hi
Probably a v minor issue compared to most but would appreciate some guidance.
Basically the hot tap pipe for the bathroom sink has been leaking for some time. It clearly needs replacing but in between now and getting someone in i wanted to seal the base of the pipe where it meets floor with some sealant. To do so it needs to be dry but the leak seems fairly constant.
To enable it to dry out before sealing i was going to shut off the house water supply and run the tap until it was empty. Is this the best approach or am i missing something?
Thanks in advance.
Thanks in advance.
