Morning all,
I got home last night and noticed a slightly wet ceiling with water dripping from a fairly new extension (built and plumbed about 6 months ago) - had a look upstairs and couldn't see anything obvious (room above is a (second) bathroom) - no water has been used in this bathroom since Saturday, in fact, nobody has been in the room since Saturday, so nothing has moved, nothing has been changed etc etc - I'm pretty sure the leak has started by itself is what I'm saying.
I've turned the water off at the mains for the time being, getting floorboards up is going to be a slight pain.
A few questions:
1 - As it was plumbed within the last 6 months and I'm confident it's not been damaged, i'm assuming the plumber should take responsibility and fix the problem FOC ?
2 - I know that when the plumbing was done, they put a new plastic pipe going from the existing part of the house into the extension and then went back to copper under the floorboards, so no plastic pipe / connections are visible. I'm pretty sure it's the speedfit connections that have failed based on where the water is visible. Has anyone here heard of speedfit fittings failing in hot weather?
I was speaking to a friend last night that's an electrician (so he see's all sorts happening in houses; hence me asking him) if he was aware of plumbing problems caused by hot weather.... so he starts telling me he's had 4 leaks in his bathroom in the past week; all speedfit fittings failing! - fortunately for him, they are all above the floorboards, so nice and easy to find! - but he's put it down to the hot weather and expanding / cooling down.
I was a bit surprised, as surely these fittings see very hot water going through them on a regular basis - but then, that's on the inside... does the outside struggle with high temps? - personally I didn't think it was THAT hot inside, but who knows? I guess it must be heat, unless they've spontaneously failed - but seems odd that a friend has also had 4 fail the same week when we have unusually high temps in the UK? (32c+)
Any thoughts?
Chris
A few questions:
Any thoughts?
Chris
