I have a long standing issue with my combi boiler, a Ravenheat RSF 820/20 which I guess is 10 years old now. Over the years I have successfully replaced many parts HOWEVER one issue remains.
The 3 bar pressure release value leaks even at pressures below 1 bar. This I do not understand as the part is fairly new and is one of 3 I have fitted all of which seem to suffer the same fate.
For example, I decided that maybe the issue was with the water pressure gauge giving faulty readings. This I replaced having released the excess pressure from the system first using the pressure release valve. I then repressurised the system to 1 bar and the pressure release valve just slowly let the water trickle out of the overflow until the pressure dropped to nothing.
What I am missing here ? The valves are new and the issue persists with more than one of them. The pressure is correct, there isn't a faultly reading. Sometimes if left a while the pressure remains stable, then it drops right down. I repressurise the system only to find the next day the reading is now closer to 2 bar.
I might add that all adjustments are done when the system is cold and the heating has been off all day to avoid hot water influencing the readings.
Something is fundamentally wrong here and its driving me mad. Anyone any idea ?
