- Joined
- 3 Feb 2005
- Messages
- 5
- Reaction score
- 0
- Country
My Potterton Combi 80 boiler loses pressure quickly and I expect the reason for this is that water is currently constantly dripping out of the pressure relief pipe. Reading numerous posts on this forum I reach the conclusion that my Pressure Relief Valve needs replacing. This has been happening since I manually operated the PRV to reduce excessive pressure recently when it had reached 3.5 bar. This also leads me to think that the PRV is faulty in that it did not automatically open when the pressure went over 3 bar. I just turned the red cap on the PRV anti-clockwise a bit to manually open it - was this right?
I shall try to source a new PRV. Could you please advise if fitting the new one is just a matter of tightening the nuts firmly, or do I need to use some kind of sealant? Presumably I need to drain the boiler first too...?
I think I should also check my expansion vessel and possibly recharge it. I have an idea how to do this after reading some posts on the subject, but can I run this by you too please? Do I do the following:
- Empty the boiler of water (using the drain valve and not the PRV) and is this step essential? Also, any idea where this drain valve is on the Potterton Combi 80?
- Check the pressure in the expansion vessel using a car tyre gauge.
- Pump up the expansion vessel if necessary using a handheld pump, to about 1 bar (I think).
Hopefully I'm not too far off the mark but please put me right if I have got it wrong.
This is the first time I'm about to try home plumbing so any tips that will help me get it right first time will be greatly appreciated
Thanks,
Steve
Thanks,
Steve
