Hello all,
Just discovered the twin panel twin convector rad in our spare bedroom has done a impressive leak job, so pretty soggy carpet
But question is to do with what to do now.
The leak is from the rear of the front panel - appears to be a rust through pinhole - the enamel has been lifted.
So, should I try and repair (weld, or glue or similar), or should I assume that if it has rusted here, it's probably on its last legs and should be replaced? (Toolstation replacement £62 so not too bad)
Second question. The water that leaks is pretty clean which makes me think there is no inhibitor in the system. So, on replacement/repair, should I then flush the system with flushing chemicals just in case, or just add some inhibitor?
Is this stuff any good http://www.toolstation.com/shop/Hea...caler+Inhibitor+All+in+One/d230/sd2708/p45091 which allegedly does both?
TIA
James
TIA
James
