Hi - I have builders in at the moment.
They must have slightly damaged the flow stem on one of the rads as now it's leaking - about 2 litres an hour.
I have a conventional central heating system with a feed tank in the loft.
I'm reasonably handy with rads but tightening the valve hasn't worked.
They're fixing it tomorrow anyway - but I just want to check that this volume of water leaking from my system isn't going to cause any issues?
Presumably my loft feed tank will just compensate for the loss of water until it's fixed and I can run the heating until then?
Many thanks
Many thanks
