Leaking rad valve
1 Jan 2013
Sheffield
I have a rad in the hallway, ground floor. Left side as you look at it is what I can only describe as a valve with a y piece off it at the bottom to attach a hose pipe for draining. On the right hand side there is a valve to open and close with a + & - on the top, however, I don't seem to be able to get the top off the valve. Usually you can prise a lid off revealing a Phillips screw underneath but not this one. How do I get this off to repack/tighten the nut???
If there is no blanking cap on the lid then it isn't screwed on it just pushes on and they can be a bit stiff to get off so get a large spanner under it and gently lever, if it doesn't come off then it is screwed on.
