Leaking Radiator Valve 3/4 inch
28 Jul 2005
Bristol
Hello Everyone,
I need to take a rad off for decorating purposes. The valve on the right is leaking slightly from its connection to the pipe coming up through the floor. Then when the rad is off it leaks periodically from where it would connect to the rad.
As far as I can tell it is a 3/4 inch valve. Would this be right?
Can you still get a 3/4 inch rad valve and some sort of stop end for where it would attach to the rad.
Any help
thats a rad valve with 3/4" connection.
and thats a 3/4" cap end. just get a 3/4" rubber washer place it in the end and screw it on.
