W
weegieavlover
Hi All,
First off I apologise for the length of this post, just want to give as much information as I can.
I have what I call 2 brick built sheds in my back garden. However these are the old coal and ash storage buildings.
They are separated by a single brick wall, each have a wooden door (we had them fitted) with, what I can only describe as, a roof made up of old rubble and brick that have been set in concrete – this is original as far as I know.
So if you look at It front on you have the two doors.
The outside left wall is 2 bricks thick and rises above the level of the roof by about 3ft. However there is a section that is only 1 brick thick that (I assume) used to be a door where the coal used to be loaded into from the lane. There is also a wooden lintel at the point above the door and that is rotten and very wet from water.
The outside right wall is actually attached to the end of the house, so again, is 2 bricks thick and rises above the roof level.
The rear wall also rises above the height of the roof by about 3ft and (I think) is 2 bricks thick.
I wanted to use these buildings for storage however with the walls being as wet as they are it is currently not possible. I had the roof tar felted and the felt went up the wall by about 6-8 inches. I then had lead flashing put round the top of felt on all walls.
I thought this would stop all the leaks and I would have fairly sound, waterproof sheds. Sadly my walls to the rear and right still seem to be wet to the touch.
I can take pictures but I am looking for advice as to what my next steps should be. I never carried out the roof work, I got pros into do it and I trust their workmanship.
I have some pictures of the outside and in (although it was dark when taken them) that I can provide, however if more pictures are needed then I can provide them as well.
I am not sure how to fix this problem, but hopefully a DIYer based solution can be used. All suggestions welcome, regardless of cost, but I do not have a load of cash to throw at this so the more pocket friendly the better.
