I wonder if anyone can suggest a solution.
We had a bathroom refurbishment 5 years ago, tiling, bath and shower over bath with screen. We had persistent leaks into our neighbours below prior to this but all but one has been solved. We've just filled holes around any pipe work with the expanding foam filler. It looks as if the bath is not set at an exact horizontal level (but only minimally out) and therefore the shower screen does not sit flash on the bath rim, although still pretty tight. Water gets between the screen door and its frame, only at bath rim level and flows onto the floor. We've tried to fill with acetate filler repeatedly to no avail. I'm now thinking of putting a strip of water resistant metal or plastic, 3 cm wide but very thin in depth that runs the whole length of the hinged join between the door and frame that it's hinged to, but cannot find anything of these dimensions in DIY shops. I don't really want to start messing with the bath horizontal level. Can anyone suggest where I might get such a strip or have an alternative suggestion? Thanks very much.
