I have an old Firebird Combi 90 oil-fired boiler. Last week the SIKA flow switch sprung a leak. The fitting isn't loose, there is a crack in the plastic. My knowledge of boilers is pretty much non-existent, but the part does look deceptively simple to replace: you remove the old switch, screw on the new one and connect the wires.
So my question is: is it really that simple? Or am I asking for trouble by trying to replace the part myself?
The boiler is otherwise working fine. I just need to close the mains valve when the hot water is not in use to stop it leaking.
