Our toilet's recently started leaking. A picture of the of the slow fill valve that's installed is below.
With the float fully raised, water still trickles down the plastic outflow pipe to the right of the foreground of the picture. It's not much, but it's noticeable enough.
I've taken the valve apart and inspected the rubber diaphragm, which appeared in good condition. I've also cleaned all accessible parts of gunk and put it all together again, which seemed to make a small improvement at first but then the leaking returned. There's a small rubber block just above a pin-hole, which sits above the diaphragm, and which I understand plays a part in the unit, but again it seems damage-free.
There don't appear to be any other serviceable parts inside.
I'd prefer not to have to replace the entire unit as this would involve removing tiling around the bottom of the toilet in order to get access to the inlet pipe. I can however easily access the shut-off valve (it's all I have access to below the cistern).
Does anyone know what I might be missing in terms of the cause of this? I can literally raise the pivot arm as high as it can go and the trickle doesn't stop.
