Leaking toilet Flex soil pipe
29 Sep 2013
Cleveland
Hi Guys
I have just installed a new toilet from Victoria Plumb, & due to awkward fitting had to use a Flexi outlet pipe. I cant stop the flex leaking at the pan (it is not as uniform a shape as maybe should be) would it be OK to try silicone around the rubber seal or not?
Silver
Not if you can possibly avoid it - it'll come back to haunt.
Have a look at the McAlpine plumbing range.....there's probably something there to help.
John :)
If it's leaking now, it will need to be fixed properly. Any type of bodge will not last. The last thing you want is to try and repair a leaking pan connector in the future leaking sewage.
Andy
