I have a problem with a toilet leaking from where the pan connects to the waste pipe. The initial leak appeared to be not from the rubber seal around the ceramic pan pipe, but from the small gap between the plastic ring at the end of the pipe and the rest of the plastic pipe. The ring can be rotated and I assume it’s something to do with the rubber seal inside the plastic pipe. It happened a few weeks ago and after I had unscrewed the toilet from the floor, disconnected the pan from the waste pipe and then put it all back together again it seemed to have cured it.
However, yesterday it began to leak again only the leak seemed to be more pronounced. I’ve disconnected the toilet again and put it back together and it now seems to be leaking from the rubber seal as well. It’s not much water as it’s simply a small quantity of water that pools in a small recess at the end of the plastic pipe everytime the toilet is flushed.
If anybody has any suggestions, other than buying a new pipe, I would be grateful. I’ve attached a picture which hopefully illustrates it better.
