- Joined
- 28 Apr 2020
- Messages
- 2
- Reaction score
- 0
- Country
Evening All,
This is my first post on here (mainly because I can always find the answer to my question!).
I’ve got two ideal standard concealed toilets which are both leaking water into the bowl. At first I thought it was a simple flush washer but no joy after replacing.
Now when I turn the water on to start filling the cistern there’s no leaking for a minute or so and then it starts to flow into the bowl at quite a rate. As soon as I turn the water off the bowl stops leaking and the cistern seems to hold water?
Ive played around with the water level but it doesn’t seem to make a difference.
For reference it’s an Ideal Standard duo flush with an internal overflow, it’s a similar unit to part # SV93467.
Any ideas would be greatly appreciated.
