Last sunday, the heating went off because of a pressure drop in the system, we had no idea where the problem was, but switched it back on. On wednesday, we discovered the pipe leading up to the new(ish) towel rail was leaking very slowly it looks like a loose nut(correct name?), I think I have the tool to tighten it, but wanted to check to be sure, because I have not done any plumbing before
The bottom part, is the part leaking
tighten with this?
tighten with this?
