Small leak has started coming from the bottom of the casing on my Triton Opal 10.5kw shower. The leak is like a tap that drips every second. It's not coming from the small plastic outlet pipe, just from the middle of the white casing at the front.
Shower still works OK, water temp fine, plenty of water from the shower head. When shower is switched off, leak stops dripping. Shower about 5 - 6 years old.
Do i live with this leak ? or have to replace the shower ? I'm a little worried as electric and water are not a good mix as to how dangerous this is!
