So under my sink its pretty straight forward there is a U-bend like trap that connects to a 90 degree fitting which at one end screws onto the U bend and the other end its a bit different.
The other end has a screw type fitting but the pipe that goes out to the drain is smaller and has no thread on it so it sort of slots over a smaller ring of the internal pipe work and then the circular plastic screw cap/head screws onto the internal pipe work.
The problem is i have a bit of a leak at this joint, even then the screw end is tightened as far as it will go the outside pipe can slide and move in/out (though to get it completely out would take a good pull).
I took it all to pieces before the house gets busy this morning and the rubber seals look fine (this pipework is only 6 months old so dont think anything has perished).
Any ideas? It certainly seems like something I should be able to fix DIY, would PTFE tape help? I am not so sure it would. I can take it all out again and take a picture if need be, for now though there's a bucket underneath so we can still use the sink.
Any advice appreciated!
