leaking underfloor pipe!
8 Apr 2007
Have recently had a solid timber floor put down(glued to concrete floor) and have discovered that we have a leak, it appears to be from pipe under the timber flooring. It is impossible to get at it without major upheaval and before resorting to that I'm wondering if there is any product that I could use(similar to radwel for car radiator) that might seal what I suspect to be a pinhole in copper pipe? would really appreciate any suggestion before I undo all the hard work! Many thanks. sweetpea0902 :confused: :confused:
Yes there is, in any plumbers merchant. Only for heating pipes, not tap water. Why should you "suspect" what you do other than wishful thinking!?
:D Thanks a million will check out the local plumber's merchant tomorrow.
