Hi all , i have a gledhill indirect stainless lite solar (not connected up or used atm ) unvented cylinder which has got my plumber baffled . About a year ago the cylinder started leaking through a small opening in the insulation at the bottom of the cylinder .my installer couldnt see where it was leaking from , but i had noticed that there was somw corrision in the thermastat under the cap.i replaced the thermostat and the leak appeared to stop, even though nobody coukd explain why this appeared to work . Today the leak has reappeared but worse with water all over the boiler room
Floor . Has anyone got any ideas as to what is happening.gledhill are pretty useless and wont pay for any labour charges and will only give a partial refund of a new cylinder once they have confirmed a fault back at base
