I have quite a bit of rainwater leaking it along the top of the frame of an upstairs upvc window. The window is set in a recess and the recess is lined with a wooden frame that is covered with a pvc panel. I've taken off the pvc panel and the water seems to be running in from the outside, along the top of the upvc frame and between the lintel and the wooden frame.
The window is hinged at the top so it is hard to lean out see what the problem is, but from what I can see I think the filler/sealant needs replacing.
I can borrow some ladders at the weekend (along with a ladder-holding friend) but as I can only use them for an hour or so I want to make best use of this time.
Can anyone offer any advice? - Are there any obvious things I should look for around the frame? Do I need to remove any existing sealer before adding more? Are there any recommended products? If it is raining or wet will the products work? Are there any signs when I get up there that this is more than a diy job?
Thanks for any suggestions.
