I may use laymen's terms here because roofing is not something I've ever dealt with, but I have bought the bungalow equivalent of the money pit. I have 2 problems:
1) I have a pitched roof that is slate tiled, with lead flashing - there is no felt below it. The valley in one part is leaking somewhere near the top and is causing water to run down the rafters inside the loft space.
I don't have a lot of money so am looking to do a cheap fix to get me through the winter and then look into a more permanent solution for the whole roof. What can I do if the lead has failed?
2) The back bedroom currently has a flat roof (also lead) which has failed before in a few places and is leaking now in one place. The roof is on joists with no isolation and a larth & plaster ceiling. - It's bloody cold in there!
I want to replace the roof and ceiling in the summer, what is the best way to replace this roof bearing in mind once the ceiling and roof come off I will only have joists left?
Thanks in advance for any help.
