My elderly neighbour has a leaking valley on a tiled roof.
Lots of the cut tiles have come loose and slipped down partially obscuring the valley and much of the bedding mortar has crumbled or come loose.
The lead itself is in pretty good condition, its just the build up of crud that has formed due to the loose tiles and mortar blocking it.
She is relatively vulnerable and i would like to oversee the repairs so just getting a handle on how extensive the tile lifting will need to be?
How feasible is it going to be to remove the valley cuts and relay them? Will lots of the roof need stripped or can the affected tiles and a few others be levered out to replace the mortar and relay?
Tiles are a double roll type pattern.
cheers.
cheers.
