I've got a drip under my bath which looks like it's coming from the seal around the body of the tap, i.e. water from the shower getting around under the tap, not the tap itself leaking.
At the moment I've used a rubber washer and plastic nut, both of which came with the tap, and I think that the washer might be folding into the hole where I've drilled through the bath.
I was thinking of swapping the nut for a brass nut and using a wider washer so that it will overlap the body of the nut and be less likely to fold into the hole.
Does anyone with more experience know of a better approach or whether this is likely to work?
