Hi all,
I've recently replaced an aging system with a push button "Fluidmaster dual flush with inlet fill valve" - and am having a bit of an issue with leaks, it's a close coupled toilet.
Am I right in assuming that, with the cistern not on the toilet, I should be able to add some water to the cistern and none of it should leak out? I'm trying to get this right before re-attaching to the wall (a right pain), it's not the main bathroom so I have time (luckily) and can now begin on something of a learning curve...
So, the water leaks from the nut that sits in the dohnut - but I've not got that far yet as I first wanted to make sure that it was all 'sealed'; the nut is tight but the water still drips out quite quickly, should I use something like plumbers mait here to help seal it off - or is there a common and obvious oversight?
